The joys of urban life! Our nearest neighbor is a quarter of a mile away and all our neighbors go to bed earlier than we do. We also have very litle traffic on our road, especially after 6PM. It makes for a quiet life.
And a very Merry Christmas to you and yours as well.Happy Christmas to you RJ, & all the Sakowski clan/s
Cheers, & lots of quiet nights too
Sorry missed the email prompt.And a very Merry Christmas to you and yours as well.
BTW, I had the tuning software all along. I had downloaded the compressed file before I actually got the driver and hadn't bothered to install it. My issue now is that I can't establish the COM link. I wired up my own cable and as I recall, the RXD and TXD lines are crossed, but no joy. I checked my COM port on my laptop with a loopback connection and it is functioning. There's no way of checking the driver end though.
Maybe it's a sign. The first rule of engineering is if its working, don't fix it.
Great stuff RJ, what was on laptop, win 7?I finally got the driver to communicate with a computer, an old desktop running XT. For some reason, it won't communicate with my laptop with identical COM port settings.
Anyway, the settings of interest are: encoder resolution, 4000; lock shaft current 40% of max; max following error 4000 counts; motor peak current, 8 amps.; and closed loop holding current, 45%.
The laptop is running Win 7 Ultimate and the COM port is on the docking station. I thought that I had solved the mystery when I discovered an internal connection between the RI pin and the DTR in the RS232 plug which I removed with a .045" drill but it is still not working. I tried using a USB to RS 232 adapter but the lowest available COM port was 15 and the software only allows up to COM 10. .Great stuff RJ, what was on laptop, win 7?
Been trying to find this,
an interesting link re certain type of lower count encoder, cheeeep, but issues:
Pauper's Rotary Encoder - Codrey Electronics
Quadrature Encoder is a familiar everyday sensor in robotics world. A quadrature encoder is a handy rotary encoder that let you know the speed and direction of a rotating shaft or linear motion. Let’s start […]www.codrey.com
I had been warned a while back re those rs232 adapters, compatibility. Thanks for that info re port limits.The laptop is running Win 7 Ultimate and the COM port is on the docking station. I thought that I had solved the mystery when I discovered an internal connection between the RI pin and the DTR in the RS232 plug which I removed with a .045" drill but it is still not working. I tried using a USB to RS 232 adapter but the lowest available COM port was 15 and the software only allows up to COM 10. .
I have another small desktop with an RS232 port which I will try. I would like to have the ability to make changes in situ if necessary.
Thanks for the link on the encoder. An interesting read.
