I completed the ELS build this afternoon. The last task was to make the faceplate for the display module. I used a piece of .063" sheet aluminum for the panel. I used my spindle mounted microscope in the Tormach CNC is an optical comparator to scan the display pcb to determine the position of the components and laid out the panel in SolidWorks. Since I had no way to make the flexible keypad, I opted for simple round buttons. For a bezel for the seven segment display, I used a piece of 1/8" red acrylic and I milled a shoulder around the perimeter so the bezel would be flush with the front of the panel but still retained by the seven segment display. This required .330" standoffs for the display pcb mount. For the push button switches, I made Delrin top hat button extensions,
I replaced the original LED's with new so I could take advantage of the longer leads to bring the LED's through the panel. The panel lettering was set up in SolidWorks. In engraving fonts, it is desireable to use a single line font. Unfortunately, Truetype fons are outline fonts. I chose the SWGDT font as the spacing is close enough that for all intents and purposes, it is a single line. For the switch lables, I used a 6 pt. font to avoid crowding due to the close spacing of the switches. For the LED's, the spacing was more relaxed so I used a 9 pt. font there. The G code was done in SprutCam. Engraving was .008" deep, using a 30º engraving tool. I chose .187" for the push button diameter so I could use my 3/16" 5C collet in the collet chuck.
To make the seven buttons, I used 1/4" black Delrin rod with the first op done with the three jaw. I
used my carbide parting tool for all machining. To machine the button, I set up my carriage stop plus an 1/8" spacer. With this setting, I faced the top of the button. Then I pulled the spacer and cut the shoulder. Then I moved the carriage to slightly past the facing position and move the stock so that I could part a slightly over length part. The spacer was reinserted and the second part was made. Once all the buttons were made, I switched to the 5C collet chuck with a 3/16" collet. The part was inserted in the collet and the carriage set up to cut a .152" length. When using a collet in this manner, especially on a material like Delrin, it is important to use consistent torque on the chuck key as the more torque you use, the deeper the collet is seated and the longer the part will be. I tightened the key until I could just feel some resistance.
The lettering was filled in with Rustoleum flat black spray on a plastic sheet and applied with a swab. The excess was sanded off with 360 grit wet and the faceplate was coated with automotive clear coat.
The enclosure is a phenolic box acquired many years ago. It is mounted on a second box made from a piece of 3" aluminum channel and a cover plate. This box houses the two power switches, one for the driver and the other for the controller, plus a fuse. That box is mounted on a repurposed residential mains fuse box which contains the 42 volt power supply for the driver, a 5 volt power supply for the Clough42 board and Launchpad. and the stepper driver.
ELS Faceplate back
ELS Faceplate front
ELS Control and Power enclosures, mounted
ELS mechanical
