- Feb 1, 2015
- 10,092
I basically use the same dilution method, mostly for my convenience. The label on my Sunnyside Muriatic Acid state 31.45%. And reaction rates are very definitely influenced by temperature. A rule of thumb is the reaction rate doubles for every 10ºC increase.When I create a pickling solution, I add water until I can no longer see fumes rising. Even a diluted solution like this is still strong enough to reduce the scale to sludge in less than 30 minutes. At most, you should see almost complete removal in less than an hour (the temperature may have an effect on the speed of removal - where I live 85º to 90º is the norm). YMMV
