- Feb 1, 2015
- 10,092
I use brute force. I just use hydrochloric (muriatic) acid as it works the quickest. FECl3 is one of the most soluble iron salts. I dilute the full strength (31%) HCl to 50/50 with water, mainly to avoid the acid vapors from the full strength acid. When finished, I rinse the parts thoroughly with water. If I am concerned about any residual acid on the part, I either heat the part or wash with a baking soda solution, followed by a thorough water rinse. The raw metal is extremely vulnerable to flash rusting when wet so I dry as thoroughly as possible. This is where the heating helps.
A second choice for removing scale is phosphoric acid, available in a gel formulation. It can be liberally painted on a large area or applied in spots. It isn't as fast as HCl but it does work.
Any acid wash will also attack bare metal so if dimensions are important, a process like electrolysis is a better option. If using NaCl for the electrolyte, be aware the chlorine gas is one of the products of the process so it is best done outdoors. Washing soda (Na2CO3) is a safer choice. I have tried the EvapoRust but I am unimpressed with the results. I haven't ever had enough molasses around to give it a go. Maybe a trip to the local feed mill?
I will often use mechanical means to hasten the rust and scale removal process. Used 40 grit or 60 grit sanding belts work well to scarify the scale. They are waterproof so they can be used wet. The final cleanup can then be the acid bath. If I am just trying to remove scale to prevent wear on my cutting tools, just breaking the scale with mechanical means is often enough as the scale is brittle and will flake off when the cutting tool hits it.
Not mentioned is removing anodizing from aluminum prior to machining. Anodizing, particularly hard anodizing, is extremely hard on cutting tools so I like to remove it. I use a dilute sodium hydroxide (NaOH), aka lye, solution to dissolve the anodizing. The process generates hydrogen gas which carries droplets of lye along with it so it is best done outdoors and wearing PPE. It vigorously attacks bare aluminum so the process needs to be monitored carefully. If the anodizing is colored, the part can be removed as soon as the color fades. Wash with a baking soda solution, followed by a thorough water rinse.
