Episode 7 || Cam Housing (with some CNC!!)
This ought to be a fun one, so buckle up! We explore the use of some basic CNC, and do a little bit of tool and cutter grinding using nothing more than a worn-out bench grinder and an electric drill.
The cam housing bolts up to the front of the crankcase with #6-32 cap screws, and registers on a boss. It’s a nice looking part, forming the aerodynamic cone at the front of the engine.
The main features at the front of the Cam Housing are pretty straightforward, complicated a little bit by a tight tolerance on the bearing housing, and the tapered cone shape at the front. The back/inside and the periphery of the housing are where things get more interesting. There’s a rectangular cutout on the underside which houses the oil pump; there are a series of 10 reamed holes around the periphery (one each associated with the intake and exhaust push rods for the 5 cylinders); and most interestingly, there is a semi-circular undercut on the inside of the housing associated with each of the 10 reamed holes.
The main OD of this part is about 3-3/4” diameter, but I had some 5” diameter stock left over from my first crankcase attempt. So I chucked that up in my 4-jaw and got to roughing out most of the stock. Lots of chips. If memory serves, I was able to take cuts about 0.100” deep or so on my lathe without chatter. I tend to hand feed, as I don’t have a quick change gear box and often feel too lazy to swap out all the gears, particularly if I’ve got it set up for threading I’m anticipating in the near future.
I wish I had grabbed a few photos earlier in the process, but must have forgotten. You get the point --- first rough off the bulk of the stock, then take off the 0.020 or so I left everywhere. Here is the part with all the turning work finished.
I brought it over to my dividing head on the Bridgeport and indicated it in on the 4-jaw chuck, grabbing it by the very small lip that registers to the crankcase. Was careful not to put too much tension on the jaws, so as not to bend or mar the surface. First step at the mill was to mill out the recess along the cone to accept the oil pump. I like to use permanent marker to keep track of my cuts, particularly if I’m taking a break half-way through an operation.
I then drilled and reamed the 10 holes around the periphery, using the dividing head to divide out the divisions, and plenty of WD-40 along the way as a lubricant. Easy peasy.
And NOW, we get to the fun part!
The 10 undercuts on the inside of the housing were a heap of fun to machine. The drawing calls for the undercuts to be a 0.200” deep semi-circle with a full diameter of 1.500”, and a 1/8” groove width. This could probably have been done by directly plunging with a cutter purpose-built for the job; I didn’t want to go that route for three reasons: (1) I was worried about chatter, as that’s a lot of cutting surface to be taking in one bite, (2) I certainly didn’t want to find/source the cutter for the job (I did search a little with limited success); and (3) I could use some of the basic CNC capabilities of my Bridgeport for a more enjoyable experience.
First, I had to take a hard look through all my drawers for a cutter that might do the trick. The ideal cutter would look something like a 1/8”-thick woodruff cutter. Problem is, none of the standard woodruff cutters are large enough in diameter to provide enough clearance to get the full 0.200” plunge without interference between the shaft of the cutter and the wall of the cam housing. Well, this is hobby machining, right? So why not use something that’s pretty close, and make it good enough?? I had a nearly perfect cutter on hand with enough clearance for the cut, but the only problem was that it was 5/32” thick rather than 1/8” thick, meaning I would somehow have to take about 0.030” off the thickness.
So I fired up my redneck T&C grinder! While the ‘finish grind’ certainly wasn’t anything worth writing home about, I ended up at essentially the exact 0.125” thickness I was looking for, and (more importantly) was able to keep it hollow-ground to prevent rubbing.
I’m fortunate to have in my shop a 1989-vintage Bridgeport with some rudimentary 2-axis CNC capabilities. It uses an EZ Trak control system (the original, not one of the later versions) with servo motors controlling the X and Y axes and glass Acu-Rite scales closing the feedback loop. Now when I say rudimentary, I mean rudimentary. All the ‘programs’ need to be entered manually at the DRO-like control box, and it really can only interpret points, lines, and arcs.* It’s awesome for what it does, but it’s nothing like any of the CNC stuff that folks are doing these days (or even a couple decades ago), not even close.
Programming in a successful toolpath took several different attempts, tons of scratch paper, and lots of time picking off points in my Fusion model. It really wouldn’t have been possible without that model.
Alright, now with everything else done, a good-enough cutter in hand, and a CNC program ‘written’, all that was left to do was make the cuts. I first ran a test cut with a permanent marker chucked up to make sure it was going to cut correctly. Then I chucked up my custom-modified woodruff cutter and let’er rip! I don’t recall exactly, but I think I took about 6 or 8 passes to get to the full 0.200” depth of cut. I had the part bolted down to the table with just one bolt right through the center; time was on my side so I kept the cuts light.
For all of those who may doubt that the modified woodruff cutter was as good as I say it was, here’s a photo of a 0.125” gage block slipping in nicely, and a 0.130” gage block not fitting. No doubt luck was on my side with this one.
Here’s the assembly through completion of the cam housing:
Not a single issue with this part, it turned out way better than I had even expected.
TIME ON CAM HOUSING: 14 hours
CUMULATIVE TIME: 88 hours
*There is a serial interface at the back of the control panel, but I have yet to experiment with feeding it through that port.
