- Feb 13, 2017
- 2,128
A few years (20+, ~1998) back, I had the hots for "Geodesic Dome" construction. Fascinated by the geometry of the triangles, I was using PVC water pipe for struts and 2 inch black sewer pipe for hubs. Schedule 40, Home Depot stuff, nothing exotic. I wanted to drill many 6 point hubs that were not symetrical at 60 degrees, so couldn't be drilled through.
I started with a step drill but that was too slow. I took a piece of rigid conduit, 1/2 inch, and cut it down to a snug fit. With cutting spurs on the end. It was only a couple inches long, I didn't intend to go completely through. With a bell reducer on the threaded end and a stub of 1/8 inch pipe to fit a drill chuck. The "drill" didn't come from HD, I acquired (stole?) a cutoff from the mill. The cutting teeth weren't evenly spaced, cut with a coarse file.
The contraption wasn't hardened, hell it wasn't even a tool grade steel. Just a piece of scrap from a conduit job. But for cutting plastic there wasn't much hardening required. I only made a hundred or so hubs, with 5 or 6 holes per hub, mostly 6. The custom drill held up through to completion of my project as well as a couple for friends. Cheap greenhouses. . . I did have to stop and punch out the slugs on occasion, that was a PITA mostly because I had to stop what I was doing and it broke my rythym.
For thinwall PVC, the pipe will tend to collapse under the pressure from a press. But with a thin wall tubing should hold up pretty well. The up side is that you don't need tool steel, even a copper tube will should hold up for a thousand or better. If the cutting edges were properly machined, it would be sharper, cutting better.
