I picked up 2 sets of these Dorian tool posts. I have 2 lathes. a 14/40 and a 12/40 It fit the 14 ok but too tall for the 12. I called Dorian they just said to buy a new one. Does anyone know how to take it apart so I can make a thinner riser for it?
Is there a nut on the top that has two indentations for a spanner wrench? If yes, removing that retainer should allow it to come apart. Should look something like this:
Looks like the bottom spacer is “pinned” to the TP body.
I’d start by removing those 3 set screws and then see if it will “unscrew” from the center threaded insert. Or maybe the whole schmozzle will slide out of the TP body once the grub screws are removed…
