Electric water heater started leaking this weekend and I changed it out today. 9 years old so I guess I should not fuss. Found out my suppliers’ heaters have a 6 year tank warranty. The other 3 suppliers here only have a 1 year warranty and all similar prices. My guy said AO Smith makes them all, and rebrands them. My problem is leaky fittings. My heater is tied to a Hardy wood heater, and the water comes through the Hardy preheated before the electric heater, with valves to bypass if needed. Many PVC fittings, elbows, valves, etc up there. There are 2 threaded PVC fittings that thread onto the copper heater inlet and outlet, and have rubber washer seals in them to seal to the copper. Both are leaking. They always leak. I tightened them as firmly as I dared with channel locks. Not sure if they are supposed to be lightly tightened or tighter than I did. Gotta cut out the PVC and start over. And the water heater is in the lowest place in the basement, so water never stops dripping to glue it. I put bread in the fitting this time that dripped. No glued joints dripped. Anybody know the correct way to install the threaded/washered fitting?
