What would I do? 20 years ago, I had a similar "thing" with a factory fridge filter and a box store "will fit" filter designed to replace it.
1, put the old filter back in, see if it leaks. If it still leaks, something happened to the seals in the fridge. If it does not leak, leave it be for long enough to acquire ONE factory original filter.
1a, aliva mentioned that fridge "might" have a bypass plug. If that's the case, install it and see if it leaks. If it still leaks, something happened to the seals in the fridge. If it does not leak, leave it there indefinitely.
2, assuming that your factory filter, or the plug fixes the leak, take the opportunity to not panic, but dig around to see what you can pick up locally for a stand alone filter housing to mount in the supply line. Make sure it's local, not "discount" quality, and the supplier is one that'll be around for a while. The first clue will be that the shelves of filters will be heavily populated with the most common filters that they sell. Don't even talk to a sales critter until you have that bit of information. After you have that information, they might talk you out of it... That's fine if they've got a good case for quality or some other thing you want or need, but make sure you're NOT buying the filter setup that they only keep one filter in stock for... Low volume items go away quick.
So... If you did have to install a brand new factory filter, by putting a (reasonable) quality stand alone filter ahead of it, that one filter in the fridge will outlast the fridge. It becomes zero maintenance. The first filter in line does the dirty work. Fifteen years out of one fridge filter (it outlasted the fridge), and five years in on the new fridge, I am quite happy with my decision to run a "primary" filter externally. Up to and including less than one minute, no "unloading the fridge", mess free filter change.
.02
.02
