Interestingly enough, I have not had any nuisance trips due to the things you might suspect (like vacuum cleaners and other motor loads). The issues I have seen seem tied to LED lighting. Again - there's no electrical spec provided to tell you exactly what situation / combination of situations is determined to be an (incipient) arc fault. I should have mentioned that my AFCIs are Square D Homeline circa 2019.
According to the US NFPA cooking was the leading cause of housefires. https://www.nfpa.org/Public-Education/Fire-causes-and-risks/Top-fire-causes/Cooking.
Also from NFPA:
GsT
Also from NFPA:
- In 2015-2019 electrical distribution or lighting equipment, such as wiring, lighting, cords, and plugs, was involved in an estimated average of roughly 32,620 reported home structure fires per year. These incidents caused an average of 430 civilian deaths, 1,070 civilian injuries, and $1.3 billion in direct property damage annually.
- Electrical distribution or lighting equipment ranked first in direct property damage, and third among the major fire causes in the number of home fires, home fire deaths and home fire injuries.
- Wiring and related equipment accounted for 6 percent of all home fires and 11 percent of all home fire deaths.
- Cords or plugs were involved in only one percent of home fires but seven percent of the deaths. Extension cords dominated the cord or plug category.
GsT
