Started disassembly of the apron
Exterior parts cleaned up and ready for paint removal
Apron comes off with four bolts from the top of the saddle. There are two locating pin's also.
Lead screw can be pulled through from the left to remove now.
Lots of cleaning ahead
Few notes on the various apron assemblies
The pin on the end of the cross feed engagement lever is mushroomed at end to retain it.
No way to disassemble with out creating a bit of additional work. I just let it be and taped around things.
There were thrust washers that were not on the parts diagram so attempted to document and keep together in the correct order.
Nut holding the clutch plates together were slightly beyond finger tight so reasonably easy to get apart for cleaning.
Worm bearing
Worm, worm bushing and casting.
Worm, worm bushing and worm bearing have seen better days. Collectively there is about .012 of play on both ends.
Clausing has the worm and bearing, bushing is discontinued.
tech support provided a copy of the original drawings for the bushing.
Got a 3" length of 660 bronze along with other needed bushings from McMaster-Carr
New Worm, worm bearing and key from Clausing. Need to turn the new bushing then start reassembly.
Onto the next phase of refurbishment Cabinet, motor, mount and c-drive assembly
c-drive bearings were shot and NOS sourced from e-bay
Cleaned up with new bearings installed.
4904 model was 3 phase from Clausing. At some point (1999) it was retrofitted with a single phase Leeson as a point of reference
Cabinet interior, there are two guide pins that align the door when closing. You can see one on the bottom right with a rusty foam pad. Frame is tapped for these.
