- Jan 19, 2012
- 182
Hopefully my drawing makes sense. I am not quite sure on the correct way to make this. At first I thought about doing the reaming and threading first. Then sawing the 3” block to one 2” and one 1” the machining the saw cut area. I think after matching there might be some alignment issues. Then I thought about machining the 2” and 1” pieces, then clamping them together some how the do the machining. Next thought was to do the machining on each part individually using the dro to reference where the holes would be. I am leaning toward the second two. how would you guys go about this? This is going to be a clamping fixture.
