This is what I am suspecting is that both contactors are being activated at the same time. That's why I am leaning towards a contactor to direction switch wiring error. Because he mentioned that the fuse to the motor did not blow I was thinking the motor was still connected when it was last triedLet me cogitate a bit on it- if the motor is disconnected and you can put it in forward and reverse without tripping the breaker
there is no way connecting the motor correctly should cause a trip- unless both KM2 and KM3 are trying to pull at the same time
but that should have shown up with the motor unhooked- check the motor connections again- shoot a picture
Ok ,So yes the motor was connected when the breaker tripped and the motor fuse did not blow
I don't think it was tested without the motor connectedIf the contactors were trying to pull at the same time then it would cause a trip with motor unhooked- pretty sure that ain't it.
We tested for that. We could test it again but I think the result would be the same
