Central machinery 12x36 wiring issues help needed
Great explanation, im starting to slowly get it. I'm used to dc voltage so it's hard to Rethink ac voltage. Ugh,Powered up fine. Put in forward and tripped the breaker but not the inline fuse to the motor. I'm sure the motor wiring is good now. Any ideas on ware to look now?I replaced all the contactors and rewired the for/rev switch a couple weeks ago.The for/rev switch wasn't even close to the manual
Can you confirm that you removed the jumpers that were put on when testing the motor separately before you reconnected it to the machine?
Yes, I disconnected jumpers. Went out this morning and disconnected the motor wires from the lathe and hooked it up to a separate cord. The motor runs fine. plugged it in and out several times.I can hear the centrifugal switch close. Rechecked voltages on post # 19 z1-z2 240 volts forward and reverse u1-v2 240 volts forward and reverse. Checked all contactors, all good. Just curios what is the black contactor thing with the dial on it in the electrical box .The large wires have continuity top to bottom? Here is how I wired the motor in the pic.The other pic shows how I wired the forward/reverse switch.
I see an error in the pic-
Well that explains it
That black thing is an overload protector for the motor, will have continuity unless it trips
Well,well, well my how the tables have turned.I It works!!!! only thing left is forward runs in reverse and reverse is forward. wire swap?
