Today my little niva die just as i pulled out of my street. I lost spark at the spark plugs, It has an electronic ignition, that i installed about a year ago, so everything is OEM parts and almost brand new. After troubleshooting i wasn't getting signal from the hall effect sensor in the distributor. I had a new in the box sensor so i replaced it, they are identical, car run but still issues running like randomly dies, and after 10 min it wouldn't run for more them 5-10 seconds, after that i replaced everything else, known good ignitor, new ignition coil, another good igniter, another coil, disconnected the tachometer, check the power everything is fine. One thing i noticed the tachometer was bouncing when i was cracking the engine. So its the Hall Sensor failure again but there must be something burning them out, what to check. The Hall Sensor is a standard type like in the picture below. Any experience or advice is much appreciated.
How long do you have to leave a spare tire in place for it to imprint it's lettering like that?
It's hard to tell you exactly what to check for, as your vehicle doesn't exist in my world, so I have no idea what makes it tick.... To get started, you want (and it sounds like you have?) a very good overview of the ignition control system layout.
The first thing I'd want to do is check the power and the ground, under load. That is, engine running and (hopefully) acting up. Make sure they're solid and steady. Best referenced directly to battery negative, and not other places that "should" be the same potential.
The second thing I'd want to do might not be so accessible. I'd want to see the return signal. (The square wave). If you can get your hands on an oscilloscope, DSO, graphing meter, or anything that could present that square wave to you, you could probably make a LOT of deductions from that information.
Short of that, a digital (not analog) volt meter, on the AC scale should show a steady AC voltage for the return signal. The actual voltage number will be meaningless, but the question would be, is that voltage constant at a steady RPM? Catching the car when it's acting up would alter that voltage reading if the signal were dropping out, and if the signal were not dropping out, you could not guarantee, but be very suspicious that the signal was not dropping out.
If you can correlate the tachometer fluctuations to an actual dropout in the signal, you've guaranteed that the loss of the distributor pickup signal is the actual cause. If you can correlate fluctuation in the power/ground circuits (While they're under a load) to the tachometer fluctuations... On the other hand, if you find a steady return signal from the hall sensor, and the tachometer still fluctuates, you can move on to the power stage/amplifier/igniter module. Or the Engine controller? I'm sure if you have one of those it isn't doing much, but again, the system layout becomes important.
You're in a spot that makes the general public hate repair professionals... A repeated failure (presumably at this point), where you are no longer trying to "prove that a part is bad". You're trying to prove that literally, everything else is good. That's a hard and frustrating thing to do. (And of course, expensive if you're paying retail....).
Before tossing any more parts, do validate the power and ground, and at least the steady AC voltage of the return signal WHILE THE CAR IS RUNNING, and hopefully get it to act up with a meter attached. That is the best direction.
Short of that, if you're gonna toss parts into the diagnostic shotgun (Hey, we've all been there...), validate that the air gaps to the sensor and the wheel are correct. Make sure there's no cracks in the wheel. Look carefully at the distrubutor cap, rotor, the carbon button, the plug wires, and the plugs themselves. Make sure all of that is in excellent condition, and there's no unnecessary restrictions to the secondary ignition that might make it want to seek it's ground via an alternate route (perhaps through the distributor housing).
