- Mar 27, 2022
- 464
I don’t see why I shouldn’t drill out the passage on the bearings but I suppose I could raise up the brass cup thing. I would have to deal with clearance issues with the headstock lid though.
I wondered about it being a shim. It would work as a reverse shim.^^^
Possible that the paper was there to fill a gap as mentioned in #25 above. Else, it was a hack shim instead of brass...
I wouldn't mess with the bearing, personally. If the gits oiler stem is only a few thou too thick, maybe sand the stem with some emery cloth?I don’t see why I shouldn’t drill out the passage on the bearings but I suppose I could raise up the brass cup thing. I would have to deal with clearance issues with the headstock lid though.
