- Oct 14, 2013
- 1,224
It's, um, a "feature"...
Sent from my SM-S911U using Tapatalk
Yep, grease will capture and hold chips and that's not what you want.My thinking is grease is just liquid sandpaper on open air surfaces like ways but great for semi enclosed area like gears and bearings...
Hi all...Yep, grease will capture and hold chips and that's not what you want.
Sliding surfaces are best off with Way Oil (ISO 68) and personally for gears and plain bearings I use ISO Hydraulic Oil (ISO 32), there may be better alternatives for the latter though.
If you reckon it'll stay chip free and it's a bugger to lubricate then that's what grease is for.Hi all...
I have some nice heavy moly grease for the concealed Crank Handle Thrust Bearings, No oil ports so grease it is...
Im a big fan of endmill holders. For smaller tools, you lose very little overhead. It saves a lot of fussing around for each tool change. Still, you need collets. So if it's one or the other, get collets.+1 on a set of R9 collets! End mill holders really aren't useful for end mills that are "small" (think: under 3/4"). And they eat up your daylight! Collets are your go-to 80% of the time, with a drill Chuck rounding out the list . Heck, I don't even OWN an end mill holder for my Rockwell mill!
