- Jul 30, 2017
- 551
Hi.. as I've been shopping, what I'm finding is exactly what your saying.. Most all end mill tooling I see is falling in the 8ths realm. I currently don't want to buy a 32nds set but I do see the the need for them due to the stricter size use requirements compared to ER collects... Thanks for the heads up, Mike.For milling, 1/8" R8 collet sizes are really all you need. The 1" size is VERY weak, BTW.
BUT, I now ALSO own a 1/64" set so I can avoid a drill Chuck in special situations My Rockwell has kinda limited daylight, and no way to add a Z spacer...
Hello Sir.. Can we talk about this quality requirement for a sec..?I'd spring for a quality set of collets. Excessive run out not only reduces accuracy, it also kills endmills so money saved on cheap collets will eventually be paid for in end mills.
I noticed shopping around this morning that most brands I've looked at have a two selections of collets, including PM, Shars, Colton and others. They all seem to have " I'm being nice here " a Good set and an even Gooder set..!
Its important to note that this will Not be my forever mill, that being said any tooling I buy now will be kept and not sold with the G0704. My big question is do I need to buy the really high end expensive brand name Collets - If so then I will buy a 1/8, 1/4, 3/8 & 1/2 for now and fill in the rest as needed, Or will a " Gooder " PM Ultra Precision set be sufficient - If so then I will definitely buy an 11pc style PM set in 16ths...?
Thanks , Mike..
Edit: just ordered the PM Ultra Precision 11pc set, I'm guessing its a middle of the road set that'll get me going...
