I am sorry I am not trying to offend you. everything I am posting is from direct experience. I will try to go back and find my emails from Remington and Fiocchi Both confirming the brass used is all the same for 223/556.
Well, I posted my experience. I'm the guy who broke the ammo down, repaired the gun and found all of the L.C. cases to have less capacity. Granted, I haven't measured the capacity of every .223/5.56 case on earth, but the three L.C. cases out of the 20 rds. of mixed brass that he reloaded were considerably smaller(internal capacity). The cases were cut on my bandsaw and the web was thicker on the L.C. cases. Maybe it was a bad lot, but it is vitually impossible for every case to be identical between manufacturers or even lots, that's why it's always recommended to start with a starting load instead of a max load.
