- Jun 19, 2012
- 47
correction. the chamber pressures are NOT different. they can be different based on loading. and the facts are you can go either way. this whole 556/223 argument is so silly it stemmed from one time barrels got mixed up in a government order of guns and the report that followed is what started this all. it is all about the max pressure and you are not going to reach blow out pressure unless you are an idiot. 556 NATO is a slightly larger chamber to allow for so many different manufacturers making ammo and the fact that people will be in the field and those just are not sanitary conditions for guns and the gun just isn't gonna be as clean as your gun at the range. 556 NATO is just built to looser tolerances other than that they are the same. go to Walmart and buy 2 different boxes of cheap ammo or go buy a box of Winchester 223 and 556 and measure the case they are the same thing. manufacturers only make one round they do not make 556 and 223 separately . I wish people would get off this kick. in over 20 years of gunsmithing I have NEVER once heard of a mishap related to using the wrong round. now I have heard of barrel obstructions but never for using 556/223 backwards.
Two comments to this post in order to provide accurate information:
1: You can shoot .223 in the 5.56 chamber, NOT 5.56 in a 223 (the dimensions are minutely different
and the chamber pressures are significantly higher in the 5.56)
2: The "denial block" in the casting / machining will not be the deciding factor on an NFA weapon,
it is the drilled hole for the auto-sear and / or any auto parts installed in the lower.
If you have further questions, feel free to ask, I will be glad to answer or provide contact info for those that can answer the question.
