I am a fan of the "package deals" which include 3 scales plus the Display. These often have a much lower total cost than separately sourcing the scales plus the display. I had wanted to get a PM728vt (mill) with the DRO and the Pedestal, but both the DRO and the Pedestal stand were back-ordered items. I ended up buying just the Mill. I fabricated a larger table with additional workspace for about the same cost as the narrow pedestal stand. I sourced through eBay a DRO kit that included 3 scales plus the display for less than $190. I liked the fact it was a set, as that gave me confidence the "pin out" of the 9 pin connectors would be matched between the scales and the display (some displays expect a different pin-out pattern than others).
The kit included a 250mm (Y-Axis), 450mm (Z-Axis), and a 500mm (X-Axis) scales. When the DRO kit arrived, it was laid out and connected at the dinner table to confirm function. It worked as advertised. I even set up some 3-2-1 blocks to act as a stop for the read heads on the table, to confirm accuracy and repeatability. It passed the test.
As with all of these kits, the bracket were largely useless, and the screw sets did not mate up with all the threaded holes on the scales (But that can be remedied with a trip to the hardware store; the threads were metric). Custom brackets had to be fabricated, but then, if you have a mill, this task is quite manageable.
There was also the incentive that the PM Factory DRO added $800 to the cost of the mill, but the kit which was purchased from eBay was less than $200. I tested it with a pair of 3-2-1 blocks and an edge finder that was 0.200 inch wide. Resolution on the scales is 0.0002 inches, the display was off by one count of resolution. With additional tests, I learned the DRO was more accurate than the hand-wheels on longer cuts, once the linear correction factor was keyed into the display.
Link to what I bought:
eBay 3 Axis DRO with Scales
