If you start looking on eBay and Amazon, you will see the same scales/displays advertised over and over again. The Chinese are masters at copying things. That means that most everything that you see will be compatible with everything else. I have displays and scales from three different suppliers. They all plugged into each other and worked. They are more accurate than my ability to measure. Scales are in the $45.00 range and displays are in the $100-something range. At those prices, just order scales and a display and use that nice bracket (the hardest part of the project).
