I make a many finishes for wood projects of various recipes from soap to beeswax. From our bees i do a very simple beeswax/mineral oil finish that i use on cutting boards, but mostly my use is as a screw lube/drawer lube. I only use the hombebrew beeswax finish as gifts to customers with the company info on it in little tins, and for the gift cutting boards (i don't sell them). All my real finishes are heavy duty, but i like the homegrown beeswax one. Varying ratios can give different results depending on what you are after. My best tip for making your own wax finishes like this is to buy a cheap electric teapot or crock pot to make it in since it the dissolved wax is impossible to clean. It is also much much much easier than using a double pot or boiler. You can just melt as much of your big beeswax chunk as you want with the electic pot - that stuff is tough to cut. If you do different finishes i'd probably buy one for each. For doling out the melted finish to smaller containers i also have a single use baster to fill tins. I also had a source for premium natural products including old fashioned turpentine, but i'd have to search for it if your interested. It was very pricey.
