- Oct 7, 2020
- 2,168
Here is my 5C collet and collet block holder/organizer I printed a while back.
Does the Gridfinity generator for Fusion automagically create the profile? I have heard that you take a picture of the object and import it into Fusion to create the cutout. Is that true?Finally getting a bit of a grip on Fusion. I'm still slow, but getting things done.
Here's the top of my Gerstner box. It's almost a perfect 5 x 13 grid, but there are heavy chamfers on the inside corners. So I went with a 5 x 12 and a 42mm wide pencil box, with chamfers. Super happy with the PLA matte charcoal from Bambu; it prints easy, looks good, has a great surface finish and feels good. As an experiment, I've been lowering the infil percentage. I'm down to 7%, and for this type of print it does'nt seem to matter.
I start with the F360 Gridfinity generator plugin to make a box the right size, then set in the tool. I spent more time than I want to admit on the test indicator, but it's printing now.
I made a few bins without lips for stacking, and realized that was an error. That should be reserved for high use items, like the deburring tool. The collet extensions and collets should be stackable, as I don't use them often. They'll go in a cabinet drawer, not the Gerstner.
PS. I have not looked into that at all but if that is the case I am on board!
Not for everybody, for sure. It fits my needs, and all those things are in that drawer at the moment. I'm adding a side tray for the most common sizes, and an under tray for the more obscure stuff. I'll actually save space.while it's nice to look at, for me it would mean many more tool boxes. I just don't have that room.
What do you mean with that explanation? It seems that you would cut (or extrude) the sketch and you would be done.How to remove an item from a model, and leave the indentation
