- Nov 23, 2020
- 820
Sounds like one of the following:
Clearly something is amiss with your technique. If you want some help with this, DM me.
- your indexable tool is either not at spindle axis height or loose in the tool post
- the insert is not properly installed, well seated, or doesn’t properly fit the toolholder (insert is upside down, wrong size for the toolholder, or the toolholder has a sloppy insert pocket)
- the compound/tool is flexing under load
- your depth of cut is too great
- you are stopping the spindle with the insert still engaged in the cut and not in a thread relief area.
Before I got the process down it was a hodgepodge off all of that.
