Hi, been recent not had much time for hobby work. Next task on the dividing head is to put graduations on the barrel, I made a degree wheel out of some aluminium sheet and a downloaded print I found on line and fitted it to the spindle of the lathe, mounted the barrel of the head in the lathe and used my thread cutting tool on it's side to cut the graduations.
I then made a little marker plate from an old brass name plate I found off an old bed. I drilled and tapped the main plate but broke the 3mm tap in the hole
and had to re-drill at the side, that is why the slots in the plate are not of equal length.
I haven't put any numbers on the barrel, it is easy to count the divisions, I haven't got room any way!
I next wanted to use the head to see if it would do it's job, I decided to make a flanged nut for the indexing plunger. I turned the end of a piece of brass
bar to the flange diameter drilled and tapped it on the lathe, centered it on the four jaw on the dividing head then mounted everything on the mill.
The eagle eyed of you will see that the whole of the indexing assembly is on the other side of the dividing head, because every thing is symmetrical
it fits on either side. The dividing head ratio is 60 to 1 so each full turn of the handle is 6 degrees, 10 turns of the handle gives me 60 degrees for the sides of the nut. Removing backlash, tightening spindle lock between cuts, 6 cuts later
Parted off on the lathe and a bit of a clean up.
And this is with it fitted.
The thing works as it should and if I was happy to leave my spur gear in the head I suppose it would be about finished. But I am not happy to do that so next
up is to try and make a worm and wheel.
