You could load it like a cannon barrel , take a paper cup line it with aluminum foil , fill it with black powder . Twist the excess aluminum foil around the top of the cup lifting it out of the cup once wrapped there's your charge . You'll need an 1/8" hole drilled about an inch past the breach plug ,, welded end ,,,. Plus you'll need a ramrod to push the charge to the bottom of the barrel breach plug. After seating the charge tamp some waddling or tennis ball go into the tank and here you need a pic to pierce the charge and push the fuse in . Oh take the ramrod out of the barrel , light your fuse and then get out to watch the fun. Then you can load and go again. 2f powder should work.
