This was more of a failure than a project, but I took my first stab at stick welding. I'm not good at MIG or TIG, but I've always been able to get the job done. My project was to use rebar to make a few trellises for the Bougainvillea. I have a small inverter stick welder and figured it would be easy enough to drive the verticals into the ground and then form and weld the horizontals in place. These will be on my backyard slopes.
I practiced running beads on scrap steel with E7018. It was a humbling experience, and
@erikmannie, my hat off to you for your pipe welding. After finally being able to run a short bead, tried tac welding a few short pieces of 3/8" rebar together. It was maddening, but alas I was able to strike an arc and keep it going, at least long enough for a tac.
Several rods and failures later, I researched welding rebar. I should have started there, and learned not all rebar is weldable. Mine is the cheap stuff from the local hardware store, and I'm sure it's not welder friendly - structurally anyway. The best I got was a weak tac that did not require much to break. I'll try again this weekend, but I think I'm going to uses baling wire to hold the pieces together. I'm open to suggestions as far as materials and process. The wood trellises at the store are too flimsy, and I'm not concerned with looks as the foliage will hide it.
