I have made a bunch of different gizmos to set the tool height in my CXA tool holders. But all of them need the tool to be mounted in the lathe. This is of course at times inconvenient, so I made a QC tool post simulator that I can use offline with the surface plate and height gauge. Bolted a trapezoidal aluminum chunk made to the right dimensions to a steel plate machined flat on the bottom with a strip on the top milled parallel. This keeps the height reference constant no matter which end of the holder the tool is on. I chucked up a short piece of round stock and cut a 60 degree point, exactly at the lathe centerline. Then with that point, I scribed a line on the tool post, measured down from the top of the tool post to the line, and then set the new target height, being the height of the aluminum toolpost minus the scribed reference setting.
it’s easy now to hit the exact height needed, for any shape tip or type of holder.
I reset all my tools, and found some set 0.020“ off. The horror of it!
