2021 POTD Thread Archive
is it sharp? it's hard to tell from the pic. but if you were working with a sharp metal edge all day, you would not like it.
I had a spackling knife like that and when doing my basement, it really left me raw.. so I always think, do I want to handle that all day.
plus, sharp may leave some marks on some stock.
Yeah. I'll soften the edges a bit.
the other night I turned some new carbon brushes for my dremel 280 (about 50 years old).
I have been having problems finding brushes, so I decided to rummage a box I bought at a garage sale about 10 years ago.
I found the right size width and height, but not the right length, or spring boss.
So with a razor saw I cut to length, and then in the lathe using a round er32 collet chucked my square brush.
a little too long.. but success. This box appears to be from at least 1954 based on the writing on it... from EAGLE ... I assume the same eagle as our oilers and electrical outlets (long ago).20210909_120149.jpg
sorry no pics of the operation or finished brushes.. just out there for ideas if you ever need it.
a little too long.. but success. This box appears to be from at least 1954 based on the writing on it... from EAGLE ... I assume the same eagle as our oilers and electrical outlets (long ago).View attachment 377952
Wow! They look new.
That box of brushes is indeed a valuable resource ... and a heck of a harage sale score!
I made a vise handle using cut-off sockets. It was my first time cutting threads, for the handle post. And I got to use my taper attachment for the handle.
edit: I did run a die over my threads to clean them up a bit. And this project also presented a reason to use my 3-axis vise (not necessary but was kind of fun).
Got a 5" 6 jaw Buck chuck that turned out to have a missing tooth on the pinion and a fair bit of wear on the teeth either side of the gap. Plus the key hole was really wallowed out (it's had a hard life I think). I ground out a slot where the tooth was and my friend used his MIG welder to fill in the gap and the keyhole
spent some quality time with the Dremel and ground a new tooth, then drilled out the keyhole and tidied it up with a carbide burr.
keyhole ended up a bit off center and kinda ugly, but the key fits snugly now, which is what matters!
Got it dialed in to a bit under 0.0005" and it appears to repeat to that too, at least at that diameter. We'll see how it does across its diameter range.
got a buddy to keep it company too :)
That's one heck of a job for a Dremel! Congratulations on a successful effort.
thanks! I was very very careful :) Feels smooth as anything too, you can't tell that it's been repaired from the outside.
