2020 POTD Thread Archive
My Seneca Falls Star 30 lathe is 100+ years old as near as I can tell. Given that, it's in pretty good shape, but the 3 jaw chuck has horrible runout: .030+ with a precision ground pin chucked up, measured as close to the jaws as I dare.
Runout at the body of the chuck near the spindle is .002 give or take, so the problem is in the scroll/jaws. It has a somewhat oddball spindle nose both in diameter and thread pitch, so a new chuck would require machining a new back plate, which I have neither the tools, the experience nor the courage to attempt.
Watched the mrpete222 (tubalcain) video where he used a tool post grinder to true up the jaws with excellent results and thought I'd try that.
The first task was to obtain a tool post grinder. Not something I foresee using a lot so couldn't see going top dollar for one, so I picked this one up off Fee Bay:
I was a little upset to find that the "motor" was a Harbor Freight router! The adapter to mount it on my AXA tool holder was very nicely machined and the router was variable speed, so I figured for the price, what the hey. A Du-All it ain't, but it's good enough for a junkyard machinist. Had to order some 1/4" shank grinding stones to use as well.
The QCTP adapter hits my compound (you can see it sits a little proud of the tool post) but that put it pretty close to on center so I went with it. I'll need to modify the adapter later so I can adjust it dead nuts if need be.
Then I had to make a ring to lock the jaws with. Started with a nice piece of 4" Schedule 80 pipe. Ooops, doesn't let the jaws open wide enough to take the stone. Poop. Hey, here's a nice piece of 6"...cut a ring off that and....oooops, now the jaws don't open far enough to lock on the ring. Rats. Rummage around in my cultch pile without much hope of finding anything when I came across a piece of 5 inch Schedule 80. Cut a ring off THAT and "Say, that should work!" Except that the thickness of the pipe wall blocked the outer bolt hole on the jaw. Fortunately, I have a mill, so I marked the spots on the ring that needed to be relieved and notched them with a 3/8" end mill (jaw bolts are 5/16")
Got everything mounted and aligned and very gingerly started kissing the jaws with the grinding stone and the chuck running in opposite directions (sure glad I took the time to wire up that reversing switch a couple of weeks ago...) Things seemed to be progressing okay until I started getting a LOT of vibration. What the...oh. The stone was mounted to the mandrel with a screw which had come loose, and the router was mounted to the tool post adapter with set screws, which had ALSO come loose. Put locktite on all the fasteners, realigned everything and went back to grinding. Slllooooooow and easy. Advance the stone a couple of thou, make several passes in and out, advance, rinse, repeat.
I knew my #3 jaw was the loosest, so I worked it until it was just kissed all the way across. Runout now is ~ .008 which is still bad, but WAY better than it was. I'll set up and polish them a bit more as I can still see a dull spot on the #3 jaw. I quit at that point because I wanted to make sure I was making things better, not worse and I had to take the setup down to chuck up the pin and re-indicate.
Overall, I'm pleased with the outcome, especially given my cheesy equipment and lack of experience. Turned a piece of 1" stock with nice results, faced it, bored a hole in it and even got my cutoff tool working like it should. Life is good...
Fired up the newest rocket stove the past few nights . This thing works great ! Buried the IR thermometer at 932 degrees . Loaded it completely up over the top and woke up this morning with absolutely nothing in the bottom . This was a 24" x 24" hopper in its' original usage . I put some nice legs on it , some stainless handles and it will be put to good use up in the Adirondacks in a week .
I also have some extra space in the garage , a drill press , a bench grinder and the large belt/disk sander left . I can now get the log splitter in the garage for the winter ! ( well ……………………...almost ) :big grin:
I made a couple of accessories for my newly acquired U3 Universal Grinder.
After watching Robin Renzetti's excellent video (
) on modifications he made to his universal grinder, I purchased additional grinding wheel hubs so that I can quickly swap between wheels and keep the wheel alignment consistent. To swap wheels I needed a removal tool as Robin shows in his video.
For proof of my design, I turned a piece of 1020 with a hex key at one end to remove the securing bolt on the hub and a threaded push rod end to remove the hub from the taper.
This works really well and I'll now make another in 4140 as it will be a little more robust.
The attachment used for holding lathe tool bits has a 21mm x 21mm capacity.
I use 12mm x 12mm HSS tools so holding my tools in the attachment just wasn't going to work. I milled a scrap of 1045 to make a holder that now holds the HSS tool in the attachment. To square the scrap piece, I used Joe Pieczynski’s method he shows in this video -
- a great time saver.
David P
Well i've been cleaning my big garage, it's astonishing how much garbage has accumulated in such short time, i've spent entire week's evening, shorting tools, gathering and throwing away garbage, i'm at my second package of garbage bags and i still have lots to do. But it's nice to have the full length garage again, i'm also having to start one more project that i'll share it onece it gets started. Don't let your shop to get this dirty, it's astonishing how much effort is needed to get it clean.
I cut all the steel for a lifting arm for my toy forklift. Welding to follow.
I have a sticker for it that says: CAUTION-I did all the welding myself. That makes it OSHA compliant...
Robert
What's it for, @rwm? Mounting a heavy bag? A gambrel for plucking chickens? A jib crane for hoisting 5-gal buckets? A pinata hanger? Bedroom toys? Window washer's belay? Unless you really meant TOY forklift!
It goes on a small forklift I made years ago. One thing this will definitely be used for is moving my Harbor Freight crane up and down a few steps without begging friends to come over. Of course your ideas are good too....
R
R
Please post a picture of the forklift with the jib installed.
  • Like
Reactions: rwm
