- Nov 23, 2014
- 2,634
POTD was making a cap for the end of a debugging tool. I was using the tool to deburr the Delrin flange benders from the POTD post above and noticed some of the bits on the floor (after my annual sweeping of the shop . . .). The cap had a hole in the end. Extra bits are stored in the handle. The tool neck length is adjustable, the cap probably broke from me pushing down and driving the arbor through the bottom of the cap.
Chucked up a piece of 1” 6061 aluminum and turned a new cap. Steps are in the photos below. Figured I’d go with aluminum instead of plastic so I don’t blow a hole in the cap again.
Thanks for looking, Bruce
Blew a hole in the bottom of the deburring tool
Facing a 1" aluminum round
Cut a shoulder for the 0.872 x 10 tpi thread
Center drill
1/2" clearance hole in the cap
Boring the hole to a flat bottom
Relieved the base of the thread with a parting tool
Scratch pass, verified 10 tpi with a thread gauge
Last pass.
Pre-parting the end of the cap in prep for knurling
Knurling the cap with a Rockwin Knurlmaster hand knurling tool
Put a little chamfer on the cap edges
Parting off the cap
Set up on my Clausing lathe for facing the end with a 5 deg. angle. No DRO on the Clausing; measure movement in the Z-axis with a 2" travel dial indicator.
Cut the 5 deg. angle on the end of the cap
Could of sworn there were 4-6 bits in the deburring tool . . .
Better than new
Center drill
Last pass.
Parting off the cap
Better than new
