2019 POTD Thread Archive
Could you make a snorkel of some kind and draw air from somewhere not so dusty when the machine runs?
Yeah, I'm getting a separate canister-style filter, which will move the air intake a little further away from the bags, but when it's in use, the whole machine is enveloped in a big dust cloud
Grinding is dirty. If you put a flange on the end of your vacuum with a 45 degree flare that opes to 2-3 duct diameters wide, you will get better capture efficiency. It would work even better attached to the wheel shroud. Unfortunately, neither will make it a clean process. I put a neodymium magnet on my grinder to catch the metal. It doesn't work for the abrasive, but that's the lesser of the evils.
I've used an car air filter the big square ones they do the job very well and last decent time.
What about a long flexible plastic pipe 4-6 inches in diameter that you fold out and put the end 5 meters away? Just fold it up over the machine for transport or storage.
fixed a creaking problem on my bike that was driving me batty. 2 1/2h a day for 2 weeks of "eek, eek, eek" that was loud enough to make it embarassing to ride past school kids waiting for their bus. Had lots of time to think of a solution.
Problem - motor is not held in the frame in only one position, which allows it to shift and rub against the frame. You can see that the paint on the motor mounting pads has largely worn off and there's another worn patch just above the top one in the picture. The likely source of the noise.
attachment.php
the threaded ends of the bolts (drive side) had also started wallowing out the bolt holes, leaving "threads" in the softer material
attachment.php
The plan - bore out the drive side bolt holes to make delrin "top hat" bushings to press into the holes, keeping the bolts and motor away from the frame. On the other side, make longer top hat bushings that go through the motor, centering the bolts and space the motor away from the frame. Doing so would also require milling the thickness of the bushings (minus the considerable clearance from the factory) from the motor mounts on both sides.
First step, a piloted reamer/ boring tool out of scrap 01. The idea was to use both existing bolt holes to center the reamer and keep it perfectly aligned, then have it cut the new hole to a fixed ID. I've tried enlarging holes with a drill and it never comes out well.
Here's the tool, couple of hours work on the lathe, mill and with a file. The fattest end will also debur the hole :) Didn't bother hardening it as I figured it would be fine for the use and I was on a hard time limit - my ride in to work this morning!
attachment.php
in action
attachment.php
you can see the fretting marks on the far side where the motor is moving within the frame cradle. Tool worked well, really clean hole that was the same ID for all 3 holes.
attachment.php
Next step was machining down the motor mounts, after which I could work out the thickness of the bushings. As every single mounting point was a different thickness (~0.3mm from large to small) I split the motor and used the machined face of the case as a reference and clamped it to my mill table. First time using the clamp set, which was neat.
attachment.php
Then work out the amount to cut off the other side to get to the desired width, rebuild the motor then clamp it to the table using the 3 machined mounts as a reference surface. Clamping was a bit sketchy, but the cuts were small.
attachment.php
Widths came out to a range of 0.03mm, which was bloody fantastic.
attachment.php
Long top hat bushings, these go inside the motor where the bolts pass. Had to step ream out the bore as it was egg shaped - narrow at either end and widest in the middle where the case halves met. Probably something to do with casting the cases. These were a royal PITA to make, but eventually they fitted. Would have prefered a larger shoulder but I didn't have enough 1" delrin rod and I had 5ft of 1/2" delrin rod, so I used that instead
attachment.php
Measured again and made the top hat bushings for the other side, this was a failed one that came out too small
attachment.php
Ended up making the front one first and when I test fitted the motor there was more clearance than I liked. It was 0.15-0.2mm, as intended and down from 0.3-0.5mm as stock, but I reduced that to 0.1mm for the back two. No pictures of that as it was late and I was tired.
Finished product - you can see the larger top hat bushing on the right, but not the smaller but longer one on the left
attachment.php
This morning the first thing I said to my wife when I got to work was:
"Hello darkness, my old friend
I've come to talk with you again"
geddit?
Anyway, pleased as punch. A lot of work, but it came out just as I had planned, which is pretty satisfying. Only worry is that the motor will get hotter as it isn't directly connected to the frame any more. If that turns out to be a problem I can remake the longer top hat bushings out of alu instead.
That would work, but when it's used as a vacuum, it's moving around, and dragging a hose around would be a problem. I'm considering making a vertical extension for the air intake, but it would need some bracing to hold it in place.
Got my blower up and running, and I didn't make the spacer for the impeller wide enough, as the knife edge you see in the above post just catches on the edge of the branch input chute when the engine is running (but it clears it when turning the engine over by hand). So I made and installed a 3/16" wide spacer to move the impeller out that 3/16", and now it seems to be running fine. Didn't get a chance to test chipping branches, as it was too late when I got it done.
This may sound funny but i spent 4-5 hours clearing my big work bench, it's been couple of months since last it's been clean. But i need to do some work on it and this is the result, i have some spilled paint to clean still.
Ok, Did some more work on the Sattley Hit and Miss engine. Head had problems, Someone welded it with what looks like nickel rod, THen tried to flatten out the face with a angle grinder. Left and uneven mess that did not seal real well. Thus some fun time for me. Did not get the major portion of the time trying to get it set up in the 4 jaw on video. But did finally get it set up and part of the work recorded
Hope you enjoy.
https://youtu.be/Kj6X4RpFX6M
Still have to figure how to get these things in here.
