Thanks. I cheated and finished my tool on the surface grinder this time. It made a difference in the performance. Usually I just hit it with the pedestal grinder and call it good.
I saw an article about differential threads that I thought was very interesting.
I did some research and found some useful applications for the design but mine is just for demonstration.
I used 5/8" X 11 and 3/8" X 16 threads which gives about 0.029 movement for one turn of the crank.
As the handle is turned it threads into the stationary and also threads into the movable block which results in one thread subtracting the distance from the other. Both are right hand threads.
Some of the uses I found
Very old hand operated printing press
Screw jack
Telescope mirror adjustment
Laser alignment
I am sure there are many other uses also.
Very high degree of accuracy can be attained using different thread sizes.
Finally! After years of using a screwdriver to change the blade on my box cutter, I finally got fed up and made a thumb screw for it. Tool-less blade changes!
