2018 POTD Thread Archive
Very nice work and video.
Tip: If you truncate (flat) the indexing pin by 20-30% off the diameter in the front, it should enter and exit the hole with less fuss.
Thank you Sir and that's a great idea!
A couple of days ago my bride came in and said the "van won't start". Went out to the garage and turned the key on part way..radio on..check, turn on headlights...check...turn key to crank...click...click...click. Ok Hi impedance battery, it is 7 years old.. Time for the charger to get it started.
This is a 2003 dodge grand caravan. reached down under the dash to pull the hood release lever and it released and the plastic lever broken and fell apart. Fortunately the hood opened, got the big charger on the bat, started the van and we went for a new bat. While I was at my service guy, we discussed the broken latch...$50 with taxes. Holy crap for $2 worth of plastic. SOOOOO the rest is what we hobby machinists do to show our wives how we can fix a $50 part with $10,000 worth of equipment and 5 hours of me time.
Please enjoy and chuckle and have pitty.
Broken latch fingers.View attachment 263328 so had to get some measurements in order to make a replacement for the two broken hinge fingers. then remove the broken fingers.
So now to mill a new part out of aluminum to be attached.
So the new insert has two tapped holes for 6-32 retaining screws. However it had to be attached to the hood release handle before we could drill the cross holes in the retaining ears.
View attachment 263331View attachment 263332
View attachment 263334View attachment 263335
Guys I am not even sure why I am posting this..other than it is the thread what did you do today.
David
Did the same thing for my truck. I've replaced the handle for the rear suicide door of my extended-cab truck one or twice a year, it keeps failing the same way, and it's about $40 for the replacement non-oem part, finally decided to make the handle out of metal, It's only been 6 months, but doesn't feel like it's going to break anytime soon...
Project I did a few days ago was to build a magnetic hall sensor pickup. This uses a small IC embedded at the tip, machined the body and the nuts out of aluminum. It is designed to be used with a MachTach Tachometer system.
View attachment 264153View attachment 264154
Is there a reason you made one from scratch instead of using one commercially available?
I had a MachTach kit delivered yesterday.
Nice work
Hi Jeff,
I prefer the hall senor over the optical in most cases, you can also get the machtTach with a slot optical sensor and a gear tooth sensor. This sender is for Paco's Acra 1640 machine, I built the MachTach and used one of the Chinese magnetic hall sensors I had left over from another system which I used a smaller sensor. We are having some issues with the sensor being somewhat erratic at times, so I decided to use the small IC chip that MachTach provides, but they are fragile and not easy to install. I use the same IC on my lathe and it works well. I decided to build a more traditional hall sensor threaded body and embedded the sensor/wiring at the tip. You need to be careful not to short or break the leads and the sensor is positional so I have an index mark on the threaded body for the rotational orientation. The magnetic hall sensors typically have a sensing range of around 1/2" but it can be affected by other steel parts that can become magnetized or issues with the flux fields which is what I believe we are seeing in Paco's system. I have another sensor which is a shielded type, so we will see which works better.
The MachTach seems to be a bit more sensitive to electrical noise and requires some tweaking to work with the sensors, at least in my experience with them. Also if you use shielded cable to the sensor, do not ground the shield at either end, the VFD noise through the ground shield will play havoc with the readings if grounded to the machine. The magnetic hall sensor needs to be triggered by the north pole of the magnet, and at least on my test bench worked better with the sensor to magnet distance of around 0.1-0.15". If you have a compass, the north pole of the magnet will swing the needle to 0 degrees, the south pole to 180 degrees.
Mark
Mark
Thanks for the detailed explanation.
As far a using a shielded cable but not grounding it on either end would negate using a shielded cable, would it not? I have in the past twisted the wires to help in eliminating noise. This is my first experience with MachTach so I thank you for the info. I will put it on my mill with a 3 ph VFD motor upgrade.
Let me know if this fixes Paco’s problems if you would. I’ll be watching his thread.
Jeff
Durn! Beautiful tool. I hope BGHansen sees your post. I'll be he could use such a punch when fabricating Erector Set parts.
Thank you much.
I think I've seen his erector sets. I know I've seen punch presses go for cheap so even if he doesn't have one it might be worth it if he's making them in any quantity.
