- Nov 14, 2014
- 848
I made a replacement double pulley for a friend's snow blower (he bought a larger engine for it and the new engine had a larger (1 in) shaft.) Initially he just wanted me to bore out the original pulley, but there was not enough metal to allow for adequate threads for the bolt that holds the key/pulley on the shaft. It came out pretty good. I needed to borrow a broach set from a friend so I got to use my recently aquired 20 ton press on the project (worked great!). Also got to use my new Kennametal tap on this project. Now I am spoiled - I need to get rid of my crappy Chinese tap set and buy a new Kennametal set!
Rick
Rick, how do you center the broach with the ID, so it cuts perfectly vertically (or should i say at right angles) into the work?? Always wondered about this.
Thanks
Glenn
