that's not really money spent but satisfaction gained.
What exactly are you doing to the treadmill pulley? Mine is also a threaded mount onto the motor, which uses a 'different' serpentine setup
Dang, that's a good idea. Never thought of that.I'm going to turn down the multi-V boss to mount a standard V-pulley to match it up to the intermediate pulley on my drill press
here's the pulley - ID is 1" by 0.5"
that set screw (plus possibly another one) will also go through the flywheel boss to tighten against a flat on the motor shaft, to prevent the flywheel from unscrewing.
I was looking at removing the armature and turning the shaft down to put the TM motor on my drill press.
I'll have to have a look at this option now.
