- Feb 7, 2013
- 2,555
A bridge rectifier is simply 4 diodes hooked in a ring. You can test all four
diodes to determine if each one conducts one way but not the other.
Usually a bad diode will be shorted if it fails from an overload. If it trips
the breaker, you can be relatively sure the diodes are shorted.
edit: For clarification, this can be accomplished with any simple analog
or digital volt-ohm meter. Personally I prefer an analog meter
for these kinds of tests but a digital one would work as well.
I use the X100 scale in resistance (ohms) for this as
one can quickly see the forward and backward resistances.
