- Sep 28, 2013
- 4,413
bunch of reasons:
- smaller pulley than I can get with a V-belt (min. 2in diameter - what I put on originally - for a 1/2in belt and even then it slipped occasionally). I wanted to gear down the motor so the spindle rpm range was more useful
- less slippage, although that's not a big deal as there's only a 3/8 v belt going to the spindle
- pulley should be concentric to the motor spindle = less vibration (ha!). It wasn't trivial adapting a V-pulley to the motor spindle and although it worked, it was hard to get it running true. If I'd made on from scratch with the LH threads and right bore size, that would probably not have been a big deal
- more mass/ rotational inertia for heavy or interrupted cuts. Motor speed used to vary a fair bit (simple MC controller), now with the flywheel on it doesn't vary much at all, even though I have only a couple of hours on it.
- built in fan. I made one for mine out of a 120mm PC fan which worked wonderfully until I accidentally moved the lathe a smidge and forgot to move it back. V belt pushed fan into fan shroud = no fan = hot motor
The smaller pulley (and larger countershaft pulley) alone has made a huge difference - low gear is now 300-1000rpm instead of 600-2000rpm, which means I don't have to use the back gears quite as much. My lowest useable speed is now 30rpm
