- Jan 31, 2016
- 13,397
Had to make a pin setting gage at work last night with four .250 slots equally spaced at 11.000 . Our shop mill ( Clausing Kondia ) has a 48" table with a non-working x axis readout and x axis power feed . Wouldn't you know it , couldn't get the 33" travel I needed . So , I put 2 tooling holes in the 67.5" long gage and had to pick them up and work backwards , then forwards and also compensate for the backlash . After cutting these slots , the boss realized we had a bigger mill in our lower shop with a working DRO that I could use to check the true position of the slots . I had 3 perfectly spaced slots at 11.005 instead of the 11.000 needed . Leadscrew error ! Tonight I will make the 4 blocks over , then take and re-machine the slots on the bigger mill . After the results , the big man said he will allocate the $$$ and we will now be getting a new workable DRO for our mill finally . Hot darn .
