Bought a Snapper 52 hydro walk behind mower and then worked on servicing it. Lubed and changed engine oil/filter, sharpened blades. Used my fancy home-made blade sharpener, which worked great. The blades were so dull, after sharpening each side of a blade, I had to adjust the grinding wheel down.
Still to do:
-replace the hydraulic fluid/filter [not done because I couldn't get the filter today]
-figure out how to inflate one of the front tires. can't get it to seal along the bead, tried wiping/rubbing the tire and rim surface down with a rag, spraying on windex [helps with making it seal just enough to get air pressure to hold it on the bead, didn't work], trying green slime around the bead on each side overnight and see about inflating it tomorrow. If that doesn't work, see I can get proper "rim sealant"
-fix the deck height adjustment screws. it's stupid that they are way up at the front of the deck and sticking up above the frame, so something solid can hit them and bent them over a bit, and they are threaded screws...
It's a little tricky to drive, left and right levers on a horizontal handlebar, you have to hold both in the 'middle' of their range of travel to be stationary, you release [so it goes forward] one or both levers to turn forwards/go forward, and pull one or both levers to turn in reverse/go in reverse. And it's faster than my Gravely Zero Turn. There will be a little bit of a learning curve for me.
Bone-headed mistake of the day: while warming up the motor to change the oil, was leaning over to look at the hydraulic system, and placed my hand squarely on the spinning air inlet on the top of the motor [the grill just over the fan that pushes air over the rest of the motor]. Fortunately, the bolts holding the grill only damaged a bit of my thumb, rest of the fingertips just have a good rubbing-burn thing happening.
