- Nov 21, 2012
- 793
Just gorgeous Paul.
I was wondering what your plan is to secure all your rolling gear (cabinets and machines) for transit.
"To be revealed at a later date" would be an acceptable answer. I can wait. I just don't want to miss it.
Keep up the great work.
No great mystery for how I'll secure the cabinets. I added 21mm waterproof ply to the floor specifically to add thickness so I have 40mm of wood to screw into the floor. I bought a bunch of recessed pan fittings like these:
http://www.uscargocontrol.com/Ratch...-Rings-D-Ring-Tie-downs/Pan-Fitting-5-000-Lbs
I will use the router and rout out recesses and the fittings will be glued in, then coach screwed into the floor. This will allow me to strap from the H beams in the top corners to the floor to hold the cabinets against the walls, and then from tie-down points that are in the bottom of the walls to the recessed pan fittings for my machines like the lathe and mill. The pan fittings don't have to hold a massive amount of weight as the container should never be flipped upside down, they just have to stop the equipment from tipping or sliding around under transit by truck, rail or ship.
Paul.
