- Apr 23, 2018
- 6,540
I'm fairly certain the metallic conduit and connectors for these read heads are all grounded into loops. It's an all metallic wire harness, from plug to head. I was sure the whole thing would be grounded through the machine, which is bonded to panel and RPC earth. I drove and bonded a half dozen ground rods right there at the stem wall where the mill is sitting. I installed the ground wire from the head to the machine's casting. So everything shares common ground, nothing is insulated, everything is metal to metal. The shields don't appear correct for draining interference, but the twisted pair bundle may have a shield and drain wire in it, I haven't taken it apart to look.Can any of you that are having these problems check if your cable ground is connected to signal ground? Sounds a little bit like some kind of grounding issue. The cable shield shouldn't be grounded at both ends. That can cause a lot of issues. Also check your display end
I'm not too keen on fixing this problem with anything other than optical scales, to be honest. I'm just going to throw my wallet at the problem and it'll probably go away. I'm not going to work into the wee hours insulating and taping and shielding and testing until it does or does not go away, I am over it- I bought cheap chicom mag scales, and got what I paid for over Mitutoyo, etc. And with the magnetic technology, I'm thinking this is the fool me once, next time it's really on me.
