- Apr 23, 2018
- 6,540
Okay, I'm not holding anyone accountable for this, I attended all of my physics classes sober so it's all pretty obvious. But I had something happen today that justifies dumpster slamming magnetic scales in favor of opticals.
There I was, milling away joyfully and producing a nice part today, when the hot blue steel curls became unbearable on my skin. I set up my chip shield and finished the part. As I was tearing down, I removed the mag base on my chip shield, an aging Starrett with a real weak pull. While moving with the magnet above the table, I noticed the displays fluttering everything to the right of the decimal place on my DRO. I cussed an incantation and waved the magnet all up and down around my mill, watching the numbers change. It would do it 24" away from the scale or sensor somewhat predictably as I moved it up, down, left, and right through the air over the table.
The mag scale readers are metallic and the cables are metal shielded. They may have ground loops, which would explain the sensitivity to the field. To be honest, I don't care why the DRO responds so much, it's the fact that the numbers change in response to a common mill table tool's presence that I can't abide. I don't run the mill on faith, I run it on confidence. If I have to rely on faith that the local magnetic fields are stable in order to make a part, I'm tapping out.
This has me on Alibaba measuring up for some optical scales right now. It's not sitting easy with me. Have any of you observed such a thing?
