One caveat--torque motors (all motors designed to move things) are not efficient as RPCs. They definitely work, and if you have plenty of current available it's probably not a problem. I was limited to 20A for my 10HP RPC and it starts and runs fine because the generator and controller were designed to generate 3 phase power from single phase. I would probably need 25-30A to use a regular 10 HP 3-phase motor as a DIY RPC.
What is a phase converter? You've come to a great place to Start... How does a phase converter work and what size is most appropriate for my application? These are the two most common questions asked. Phase Converters Phase Conversion
www.northamericaphaseconverters.com
Rotary Phase Converter General Questions What is a rotary phase converter? A rotary phase converter is an efficient way to produce 3 phase power from a single phase power source. It generates one line from a generator motor and combines that with your two single phase lines. What does CNC...
Give North America Phase Converters a call. They are very knowledgeable and helpful.
