- Jan 20, 2018
- 5,640
This is how I solved that problem. I just replaced the original switch with the VFD
That's not smoke on the face of the VFD is it?
How big is your shop and how much power is coming in from the utility? Not much point on making it bigger than you can power, and unless you're running a pro shop you'll only be running one machine at a time.Well, gonna pull the trigger on a rotary. Thanks guys.
Now I am just trying to decide the size. I want to be able to run the mill and surface grinder. I eventually will have a lathe I just don't know how big the motor will be for it. Guessing the standard engine lathes/tool room lathes are 7.5-10 hp?
I have plenty of power in the shop. 400 amps of 230v. I run a marine service business. I can get 3 phase its just too much on the monthly bill unless my ideas take off.
