Back in the early 1980's, I had a little Datsun 1300 pickup. Put in an electronic ignition that was a kit. This one used the regular points in the engine as trigger. Worked great. No matter what the weather was, the truck would start immediately. The ammeter showed that the ignition used a lot less current. I tried to mount it so that there was always an air flow. Electronics and heat just don't get along. After several years, it finally gave up the ghost. No problem, there was a switch on the side of the unit. When you flip it. It would go back to standard ignition, and you are on your way.
