- Oct 5, 2010
- 1,044
Who has Dry Chemical fire extinguishers in their shop?
I learned the hard way that they do not belong in the shop. I am restoring an old 20" Powermatic band saw that must have been used mainly for cutting sheet plastic. I blew out all the saw/plastic dust I saw. There were a couple of drilled holes that needed filling up, so I got out the MIG and started filling holes. All of a sudden I noticed I had a small fire. I wasn't too concerned because I had removed the dust-Right and the saw is is all metal and I had already stripped all the innards out. All of a sudden the shop started filling up with heavy black smoke. I grabbed one of my trusty dry chemical extinguishers and then another. They worked fine but they weren't putting out the fire. I just dumped 15 pounds of dry chemical into the interior of the saw and it is still blazing. So, I grabbed the hose and the water put it out. The fire is out and I am relieved. Now the clean up. I started to sweep up the powder. It is hydrophobic and doesn't dissolve in water. The powder is like the finest talc I have ever encountered. As I start sweeping and the powder starts filling the air. I turned on the exhaust fan and that helped to clear the air. I had to put on a respirator so I could breath. I started to look at the shop. There was powder on every surface of the shop. I sweaped all the powder off the floor. Next I started cleaning my machines. I cleaned the lathe, then the mill. I looked at the lathe and it had a new layer of dust. I am going to be cleaning machines and tables for weeks. The stuff just moves from surface to surface. It is still everywhere even though 14 pounds are sitting in the trash can.
I will never use a dry extinguisher in my shop again. First thing is that it didn't put out the fire, I felt safe because I had several strategically placed through out the shop, and third it left a miserable mess. For now on it is Carbon Dioxide extinguishers for me.
On a side note I did a final inspection of the saw. Plastic does not turn into dust like wood. It forms fibers of various sizes. Those fibers migrated into the column and other not particularly accessible portions of the saw. Needless to say they burn very well. Since the fire I have probably pulled out a bushel basket full of plastic fiber. None of this fiber was noticeable in the logical places. If you cut much plastic with a wood saw, you might want to inspect your saw from time to time and pull all the clinging fibers out of your saw. They won't just blow out with an air hose. They are quire tenacious.
