- Jun 12, 2014
- 4,828
Correct, lever up is usually reverse and down is forward, but one can also reverse the feed direction at the gearbox. Pretty standard feature on full size lathes. The lever mechanism is usually notched so it locks in the stop position with a ramp from the forward/reverse positions. Some lathes it controls the motor/contactors/relays for direction, larger lathes usually use a clutch system.
