Here are some more pictures. The line of pressurized air comes out of the compressor and is "Y"'d as it enters the top of the condenser unit. The top of the condenser is cooled by both the compressor and motor fans. After the compressor has been running for a while the top coil or so of the condenser is hot but quickly cools down. By the third coil it is almost ambient temperature. The cooled air exits at the bottom where it hits a "T". The bottom of the T goes to a drip leg and the top line goes to the tank. There is a valve at the bottom of drip leg of course.
Since this is an AC coil, the condenser is rated for high pressure.
As I mention before, I made one exactly like mine for my friend. His looks a lot better than mine. I made an angle iron frame with expanded metal as a guard and I used copper pipe instead of tubing. Mine was more a proof of concept that worked better than my expectations.
